export as mp3
Re: export as mp3
Post by steve » Tue Jan 26, 2010 5:14 pm
nongeek wrote:Well, guess what! I think I have succeeded so far
Congratulations :D
nongeek wrote:how I export my music file from Audacity back into my iTunes?
Sorry, I don't use iTunes, so I'd just be reading from the instructions that WC has posted.
nongeek
Re: export as mp3
Post by nongeek » Tue Jan 26, 2010 6:24 pm
To stevethefiddle.
Many thanks for all your help.
To waxcylinder
Many thanks for your input. I have visited the link you suggested and found it very helpful and have copied the details for future reference.
I intend to export my Audacity edited tracks to iTunes via MP3 because I was under the impression it was the best way, but your suggestion has made me think again.
I wish to possibly put my tracks from iTunes onto disc, but primarily I wish to put them onto my MP3 player, which is not an iPod, so if I do decide on the disc at any time, your given advice will be very helpful. For the purpose of putting the tracks onto my MP3 player, due you recommend the MP3 format or the other two choices?
Appreciatively,
nongeek
waxcylinder
Re: export as mp3
Post by waxcylinder » Tue Jan 26, 2010 10:06 pm
If you are not using an iPod then Mp3 is probably the best choice for you - the minimum bitrate I would use is 192 for music (and I have old ears) - 128 for spoken word.
I'm puzzled though - why are you using iTunes and not using an iPod to go with it?
nongeek
Re: export as mp3
Post by nongeek » Mon Feb 01, 2010 3:27 pm
Hi all,
many thanks for the help I have received from my post on this matter. I think I have cracked it now thanks to your help. All seems to work fine. :D
Thanks again.
nongeek
