Unzip tone control file ?
rectek
Post by rectek » Mon Jan 18, 2010 5:24 pm
A recent post told how to insert a tone control file into Audacity. I can download the zipped tone control file, but even tho I did a search on this site, I cannot figure out how to unzip the " ny " file before bringing it into Audacity. ( I have 1.2.6 version - maybe that's my problem ?)
This version does more than I need it to do for my basic needs, and hope I don't have to replace it with a newer version.
Thanks in advance for your time
Re: Unzip tone control file ?
Post by steve » Mon Jan 18, 2010 5:51 pm
Sorry it requires Audacity 1.3
Audacity 1.3 is not any more "difficult" to use than the old 1.2 version, in fact you can have both versions installed on your machine at the same time as long as you only use them one at a time. Audacity 1.3 can open projects made with 1.2, but Audacity 1.2 can not open a project that has been saved by 1.3
The recommended version of Audacity 1.3.x is 1.3.11 which is currently available as an alpha version, but should become available on the normal download page in a few days.
To unzip a file in Windows XP or later, Right click on the file and select "Extract" or "Extract All".
rectek
Post by rectek » Mon Jan 18, 2010 9:00 pm
Hi
Based on your advice, I downloaded the newest beta version, and I tested it by recording some streaming audio - and it works fine.
However, I am still at a loss how to import the tone control module. I tried "import" in the file drop down, but that is apparently intended for raw audio, not zip files
In other words, I am not sure if the downloaded tone control is zipped, and if it is, I don't know how to unzip it, and lastly, I don't know how to bring it into Audacity.
Hopefully, there is already an answer on this site that you can refer me to
Thanks again for your patience and time
Post by steve » Mon Jan 18, 2010 10:02 pm
rectek wrote:I downloaded the newest beta version
I actually recommended downloading Audacity 1.3.11 when it is released (which will be in a few days time). There is a bug in the current 1.3.10 beta version that affects "Export Multiple" and "Export Selection". If you use either of these functions, the exported audio will be a few seconds longer than it should be. This may not be too important for you right now, but I definitely recommend that you update to 1.3.11 when it is released.
rectek wrote:In other words, I am not sure if the downloaded tone control is zipped,
Is this the one that you are talking about, or a different one: http://forum.audacityteam.org/viewtopic ... 20&p=67439
This one is definitely zipped. Downloading it and double clicking on the downloaded file will open an Explorer Window and you will see the file "tonecontrol.ny". That's the actual plug-in file.
rectek wrote:and lastly, I don't know how to bring it into Audacity.
Have you found the Audacity installation folder for the new Audacity 1.3 that you have installed? It is probably in a folder something like:
C:Program FilesAudacity 1.3 (unicode)
(don't get confused by the old Audacity folder where Audacity 1.2 was installed)
When you have found the program folder there will be a sub-folder called "Plug-ins". Open that folder and put the plug-in file (tonecontrol.ny) in there.
When you restart Audacity you should see the new effect listed in the Effects menu.
rectek
Post by rectek » Mon Jan 18, 2010 10:11 pm
YES ! Your last instructions accomplished acquisition of the tone control
Thanks for help and patience
Post by steve » Mon Jan 18, 2010 10:53 pm
Do let me know how you get on with it. All comments welcome (it's one of the plug-ins that I wrote).
