I can't seem to install Audacity from CD. It'll only operate while the disc's in the Mac. What am I doing wrong?
Matt
Installation on Mac OSX
Mat Watkinson
richardash1981
Re: Installation on Mac OSX
Not copying the audacity installation to your hard drive. You need to Option-Drag the whole of the contents of the .dmg file from where they are to your applications folder (or wherever else you like to put it), and then you will actually have copied the application, not just created a link to it (the default action when you drag and drop).
