budget (usb) mic for classical guitar recording needed
Did you buy a new mixer? Do you need advice? Post here.
Re: budget (usb) mic for classical guitar recording needed
Post by kozikowski » Fri Mar 26, 2010 10:50 pm
Oh, yes. Before we leave this completely. Can you post that picture of proper microphone placement?
bgravato
Operating System: Linux Debian
Post by bgravato » Tue Mar 30, 2010 12:26 am
kozikowski wrote:Oh, yes. Before we leave this completely. Can you post that picture of proper microphone placement?
yes, here they are:
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Post by steve » Tue Mar 30, 2010 12:53 am
It's pretty impressive that you are getting such low noise from what is still a relatively "budget" pre-amp - that's quite a distance between the mic and the guitar, but it shows very well how it is able to pick up the whole of the guitar sound and some room ambiance.
I presume that you still using it on the cardioid setting? If so, it may be worth trying it on omni as that will allow you to pick up the same amount of room ambiance at a much closer distance to the guitar. Also, the "proximity" effect should be much less on "omni".
(Proximity effect: the tendency of microphones to accentuate the bass frequencies when used close to a sound source. )
Post by kozikowski » Tue Mar 30, 2010 12:55 am
Excellent. Yes, that's what I want to do with the hallway here at work. And if you move the mic too much either direction along the instrument, it starts sounding wimpy or boomy?
bgravato
Post by bgravato » Tue Mar 30, 2010 1:37 am
stevethefiddle wrote:It's pretty impressive that you are getting such low noise from what is still a relatively "budget" pre-amp - that's quite a distance between the mic and the guitar, but it shows very well how it is able to pick up the whole of the guitar sound and some room ambiance.
Yes, still using cardioid. I tried omni once briefly but I didn't like much the sound from it, so I went back to cardioid. I think I didn't change the position of the mic though... so I shall try again in a closer position...
Post by steve » Tue Mar 30, 2010 1:43 am
bgravato wrote:I think I didn't change the position of the mic though... so I shall try again in a closer position...
And at the top of the stairs ;)
Have you thought about putting a safety strap round the mic/mic stand - perhaps it's the photographs, but it looks pretty close to the edge :?
bgravato
Post by bgravato » Tue Mar 30, 2010 1:45 am
kozikowski wrote:Excellent. Yes, that's what I want to do with the hallway here at work. And if you move the mic too much either direction along the instrument, it starts sounding wimpy or boomy?
I didn't try to move it along, but occasionally I unconsciously move/rotate myself and slightly change my position while playing and I noticed that probably due to that at some parts of my recordings the sound became a bit more boomy, probably when I moved the guitar hole closer to the mic...
You also probably noticed that I don't put the mic in a vertical position... I do that for two reasons:
1) when I'm playing the guitar is usually not in a vertical position either... so I tried to place the mic more or less parallel to the guitar
2) when the mic is facing slightly down like in the pics it seems to capture a better ambience sound than when I positioned it vertically
bgravato
Post by bgravato » Tue Mar 30, 2010 2:07 am
stevethefiddle wrote:Have you thought about putting a safety strap round the mic/mic stand - perhaps it's the photographs, but it looks pretty close to the edge :?
It's the photographs :P It's pretty safe. It's much more prone to being slapped by my myself or the guitar when I sit down/stand up than falling down the stairs :)
Here's a pic taken from behind where I sit:
Post by steve » Tue Mar 30, 2010 2:31 am
bgravato wrote:Here's a pic taken from behind where I sit:
Phew, I can rest easy now :D
(one of my duties at work is "Health and Safety", but I'll avoid commenting on the lead trailing across the top of the stairs... oops, too late :lol: )
bgravato wrote:when I'm playing the guitar is usually not in a vertical position either... so I tried to place the mic more or less parallel to the guitar
That's the "classic" way to do it. Bit by bit you're confirming, from experiment and experience, that the text books are right.
bgravato wrote:I tried omni once briefly but I didn't like much the sound from it, so I went back to cardioid. I think I didn't change the position of the mic though... so I shall try again in a closer position...
You may find that you still prefer the cardioid setting, but with the experience and refinements that you now have available I think it would be worth trying.
bgravato
Post by bgravato » Tue Mar 30, 2010 7:36 pm
I've just tried to record some samples in the omni setting. It sounds more "distant" like if the mic was standing much further away from the guitar... Placing the mic closer to the guitar of course reduces this effect, but then it starts to sound a bit more boomy...
I've also been playing around with opening/closing the doors in the stairway hall to change the echo/reverb effect. With all doors closed it's interesting to listen while I play but then on the recording it's just too much reverb, specially in the omni setting... but that's what I was expecting...
(hopefully in a not so distant future I will get all variables settled and start doing some more serious recording :P
