Export at 128kbps instead of 320, help please
This section is now closed
Samoth
Post by Samoth » Mon Dec 24, 2007 6:22 pm
:D
I while ago I changed the settings to export all files at 320kbps, now I need the files to be smaller and I carnt remember how to change it back. Ive looked through all the preferences but couldn't see anything...
Re: Export at 128kbps instead of 320, help please
Post by steve » Mon Dec 24, 2007 7:50 pm
Edit -> Preferences -> File Formats
There's a drop down list to selct the default bit rate for mp3's.
(Note that in Audacity v.1.3.x it is different, and is selected when you export)
Samoth
Post by Samoth » Tue Dec 25, 2007 10:26 am
Thanks but when I go to Edit, there is no preferences drop down box :|
I have 1.3.3 Beta...but when I export, it dousn't give me any options but says exporting at 320kbps :(
Post by steve » Tue Dec 25, 2007 11:01 am
This is the "Audacity Stable (1.2.x) ‹ Mac OS X" board, so I assumed you had v.1.2.x - silly me :D
So for 1.3.x, when you are ready to export your audio, click on "File ->Export..."
On the dialogue window that opens there are three buttons - "Save" , "Cancel" and "Options"
and a drop down list to select the format.
Select "MP3 Files" from the drop down list.
Then Click on "Options".
