Playback hesitates after I hit "play"
kurtw404
Post by kurtw404 » Fri Jan 08, 2010 9:44 pm
I'm running 1.2.6 on Windows 7. I've been using the software to do some fairly straightforward editing (ie, removing "um"s and "ah"s from a webinar...). I got to the 4th file (each file is about 20 mins. long), and the software developed the following problem: When I hit "play", there is a severe lag between me pressing the spacebar (or clicking "play") and playback actually happening. Sometimes as much as 10 seconds. Eventually though, it does play. I've closed and reopened the software multiple times, I've tried bumping Audacity's priority up in the task manager, I've closed processes... Rebooting the computer fixes the problem, but only for a few minutes. Has anyone else encountered this, and is there a fix? I'm up against deadline here, and I really need the software to perform. Please help!
Irish
Forum Crew
Re: Playback hesitates after I hit "play"
Post by Irish » Fri Jan 08, 2010 11:00 pm
Version 1.2 doesn't play very well with Windows 7.
Try downloading version 1.3.11 from here:
http://wiki.audacityteam.org/index.php? ... tly_Builds
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
