Kyoshi
Post
by Kyoshi » Fri Jan 08, 2010 4:23 am
How can this be fixed?
I'm using version 1.3 beta.
When I attempt to open the music file, I get the following message.
"Audacity recognized the type of the file 'C: blah blah blah blah' but was unable to import it."
Post
by kozikowski » Fri Jan 08, 2010 4:55 am
There are two ways to capture sound that gives Audacity troubles. The fastest is use the download of Super or Switch to convert the work to something Audacity can handle -- generally WAV.
Or you can play the work and record it real time in Audacity. You can do that with a program like Total Recorder, or by messing with the Windows Control Panels. This is the What-U-Hear or Mix-Out technique written about here...
http://wiki.audacityteam.org/index.php? ... e_computer
Windows Media has two "problems." It's a proprietary format, so it's a little rough to deal with right there, and if you're trying to manage a copy protected song, you get to fight the security layer, too.
