Notch Filter vs Vocal Remover for Center-Panned Vocals
Audio software developers forum.
charlieF
Post by charlieF » Mon Jan 04, 2010 12:34 pm
I'm trying to remove frequencies between 4750Hz and 8700 Hz for an experiment having to do with Tinnitus, see http://bit.ly/7c8IuR I used Effect:Notch Filter with Default choice set to 0, Notch Frequency at 5800 and Notch Q set to .9 It appears that the music has change but I can't tell how or what was done. It says lower Q gives a wider notch, but I can't tell how wide. There's not suppose to be any difference in the hearing of the music, which was my experience. I used Effect:Vocal Remover for Center-Panned Vocals which gave me the choice of frequencies which I could remove, which was great, but again there was no way for me to tell if I had done anything to change the music. I'm essentially trying to remove one octave total above and below 5800 Hz which is the frequency that I believe I'm getting in my ear. Any help in verifying which method is better than the other or how to verify what I've done would be appreciated.
Charlie
billw58
Re: Notch Filter vs Vocal Remover for Center-Panned Vocals
Post by billw58 » Mon Jan 04, 2010 3:08 pm
With the Notch Filter plug-in. defaul, choice = 0 removes 60 Hz, and 1 removes 50 Hz. You need to select choice = 2 in order to specify another frequency.
To see what was done to the music, select a portion then Analyse > Plot Spectrum. Set the size to 16384 and axis to log frequency.
-- Bill
