Equalizer load/save the curve into a file
This section is now closed
dportabella
Post by dportabella » Tue Dec 29, 2009 7:27 pm
Hello,
A user can draw a curve in the Equalizer effect GUI. However, I need to draw a curve and send it to a colleague:
so I need the possibility to draw a curve, save it into a file, send the file to my colleague, and that he can load the curve in the equalizer from this file.
Moreover, I would prefer to use a text editor to design a precise curve (rather than using the GUI).
Is it possible to save/load a curve into the equalizer? how?
When I draw a custom curve and give it a name, is this curve saved into a file somewhere? where?
Regards,
DAvid
billw58
Re: Equalizer load/save the curve into a file
Post by billw58 » Tue Dec 29, 2009 7:40 pm
EQ curves are saved in a file called "EQcurves.xml". It is in <your home>/Library/Application Support/audacity/.
If you carefully edit this xml file in TextEdit you can create curves to your heart's content. You could also send an appropriate portion of the curve to your friend who could paste it into the file.
-- Bill
Oops. I see you are in the 1.2.x forum. The above applies to Audacity 1.3.x. You may want to upgrade. AFAIK 1.2.x does not allow saving of custom EQ curves.
dportabella
Post by dportabella » Tue Dec 29, 2009 8:28 pm
billw58 wrote:EQ curves are saved in a file called "EQcurves.xml". It is in <your home>/Library/Application Support/audacity/.
Great, I modified that file and it works. Thanks!
billw58 wrote:Oops. I see you are in the 1.2.x forum. The above applies to Audacity 1.3.x. You may want to upgrade. AFAIK 1.2.x does not allow saving of custom EQ curves.
That was my fault. I am actually using 1.3.9.
Regards,
DAvid
Post by kozikowski » Tue Dec 29, 2009 10:02 pm
Sure. I've emailed equalizer curves to people.
I swear I did it in the earlier version, tho... I've only been using 1.3.7 for a really short time.
Post by kozikowski » Tue Dec 29, 2009 10:09 pm
This is the low cut filter characteristic of the Shure Brothers microphone filter.
http://kozco.com/tech/audacity/100Hz_Rumble.jpg
I have the data file around here somewhere.
.....OK. Maybe I don't. I can't find it on the web site. Perhaps I couldn't save it because it can't be done in 1.2.
