Hi
Icant seem to get the echo effect out of anything I record.
Any help would be appreciated.
Thanks
echo problem
Re: echo problem
I'm guessing you're recording streaming audio from the Stereo Mix (or equivalent) input.
I'm also guessing you have "Software Playthrough" turned on in Audacity's eidt -> preferences -> audio i/o menu. That's the most common cause of this problem.
If you have a different issue, you have to describe it to us.
Re: echo problem
alatham
thanks alot for the info and response.
i unchecked the playthrough and that took care of the problem.
thanks again................treedog
