STILL can't add my mic even after reading wiki
This section is now closed
elea
Post by elea » Mon Dec 14, 2009 8:56 pm
I have a Mac running on Leopard. Still can't add my USB mic as the input device, even after selecting it in the mac's sound preferences. Ideas? Thanks.
billw58
Re: STILL can't add my mic even after reading wiki
Post by billw58 » Mon Dec 14, 2009 10:31 pm
Quit Audacity. Open the Sound Preferences panel, select the USB mic under the Input tab. Start Audacty, go to Preferences, Recording tab and select the USB mic as the recording device. This works for me using Audacity 1.2.6.
You might want to consider upgrading to 1.3.10.
-- Bill
Post by kozikowski » Mon Dec 14, 2009 11:00 pm
Some USB microphones also require 44100, 16-bit, Mono instead of stereo. Reset Audacity Preferences and restart Audacity.
While you have the Apple System Preferences panel open, do you get the bouncing blue ball sound meter when you talk into the microphone? That proves that the sound is inside the Mac and you just have to go get it.
If you don't get the blue ball meter, you need to fix that first.
Post by kozikowski » Mon Dec 14, 2009 11:01 pm
Oh, and yes. Intel Macs with Leopard do not support Audacity 1.2.
