Missing tabs under Preferences
capnjack
Post by capnjack » Sat Dec 12, 2009 9:43 pm
Am unable to record in stereo. Helps tell me to go to Preferences Audio I/O but there is no such tab. The tabs are Interface, Keyboard and Mouse under Preferences nothing else. What am I missing? I am running Vista Home Premium and my USB device is a Behringer U-Phono UFO202.
Re: Missing tabs under Preferences
Post by steve » Sun Dec 13, 2009 9:28 am
capnjack wrote:Helps tell me to go to Preferences Audio I/O but there is no such tab.
Which version of Audacity are you using? (Help menu > About Audacity)
capnjack
Post by capnjack » Tue Dec 15, 2009 8:11 pm
My version is 1.2.6. I loaded this version from Behringer CD anf the same version from the Audacity site and the results are the same.
billw58
Post by billw58 » Tue Dec 15, 2009 8:13 pm
You might want to try 1.3.10. Version 1.2.6 may have problems with Vista.
-- Bill
capnjack
Post by capnjack » Tue Dec 15, 2009 8:57 pm
!.3 gives me all tabs, just appears differently. Will try to record now. Thanks!
baron5nc
Post by baron5nc » Tue Dec 15, 2009 10:35 pm
When you open preferences in 1.2 scroll left on left or right arrow heads and I believe you'll see the I/O tab
