the gain slider is the non-destructive and amplify is the destructive.Starchild wrote:stevethefiddle wrote:They both make the sound louder (or quieter), but one is a "destructive" edit (actually changes the recorded wave), and the other is "non-destructive" (doesn't change the recorded wave).
Try them both to see the difference.
Which is destructive and which in non-destructive?
i would recommend using non-destructive amplifying when possible, because sometimes amplifying and saving a track causes undesirable side effects like excess noise which you can sometimes miss at first.
if you just play with the gain slider no damage can be done to the track.
Johnny from guitars101
