Harmonizing, synth or something?
brendan
Post by brendan » Mon Dec 07, 2009 5:51 am
I'm making a song and its a remix which means its gonna be similar to the original, and the original has a lot of harmonizing init. I'm not sure how to make that harmonzing sound, or synth whatever its called. to understand what I mean listen to this song, the first verse and chorus shows what i mean
http://www.youtube.com/watch?v=4NhYsJT3O8s
if this can be done in audacity, plz tell me, if not can u tell me wt program will?
thanks
Re: Harmonizing, synth or something?
Post by kozikowski » Mon Dec 07, 2009 6:00 am
The instruments are obvious synths, but there is an effects voice in there that sound something like this...
http://www.youtube.com/watch?v=YR_Bjf-a5rs
That's a vocoder and there's one built into the effects package of Audacity 1.3.
You apply two different sounds and the vocoder changes one sound to match the other. That's the Frampton singing guitar.
You can have 1.2 and 1.3 on your machine as long as you only use one at a time. Audacity 1.3 projects will not open in 1.2.
brendan
Post by brendan » Mon Dec 07, 2009 4:36 pm
kozikowski wrote:The instruments are obvious synths, but there is an effects voice in there that sound something like this...
thanks for the reply man, I'm using 1.3 at the moment, I'll give the vocoder thing a shot then cheers mate!
