Audacity won't record!
This section is now closed
Archmaster
Post by Archmaster » Sun Dec 06, 2009 9:16 pm
I have Audacity 1.2.6 on and Intel Mac, Mac OSX 10.5.8. About three months ago, I downloaded Audacity was working fine, and I used it to make a documentary for a school project. Sometime last month, it stopped recording. I have no idea why. My Mac's built in microphone records for other programs like iMovie and Garageband, but when I press record in Audacity, I talk and nothing is recorded. I put the input and output volume to the max, and in preferences I made the recording device Mac Vide Audio Connector.
How can I fix this?
Re: Audacity won't record!
Post by kozikowski » Sun Dec 06, 2009 9:23 pm
First step: Audacity 1.2 is not supported on newer Macs. That, plus Intel Macs took (at one time) Audacity 1.2.5, not 1.2.6.
So, you should be on one of the Audacity 1.3 versions. The newest version is 1.3.10 from here...
Audacity 1.3.10 is still under hot, active development, so I use a somewhat older 1.3.7 on my Intel Macs from here...
Audacity 1.3.7 -- Mac
http://audacity.googlecode.com/files/au ... -1.3.7.zip
Archmaster
Post by Archmaster » Sun Dec 06, 2009 9:35 pm
I forgot to mention, I downloaded 1.3.9 too, but that won't record either.
Post by kozikowski » Sun Dec 06, 2009 9:39 pm
Did you install Skype in between? Skype is famous for taking over sound services and not putting them back.
Apple > System Preferences > Hardware > Sound > Input. Is that setting still pointed to Built-In Microphone and does the blue ball sound meter jump when you talk?
Archmaster
Post by Archmaster » Sun Dec 06, 2009 9:59 pm
It was set to Mac Vide Audio Connector. I put set it to input, and no, the blue meter did nothing. How do I fix it?
Post by kozikowski » Sun Dec 06, 2009 10:19 pm
<<<Intel Mac>>>
What kind of Intel Mac? The Mac Mini does not have a built-in microphone.
Apple > About This Mac > More Info... > Hardware > Hardware Overview > Model Name.
Archmaster
Post by Archmaster » Mon Dec 07, 2009 3:25 am
It says iMac.
Post by kozikowski » Mon Dec 07, 2009 5:51 am
Excellent. We have several of those at work and yes, they do have built-in microphones and will do an iChat session with no troubles.
I can't think of a direction to go. Are you a native English speaker and is your Audacity in English? I need to ask that because you have some very strange symptoms I've never seen before and they could be caused by a "foreign" language installation.
Archmaster
Post by Archmaster » Mon Dec 07, 2009 7:06 am
I have english installed. No other languages that I am aware of.
Post by kozikowski » Mon Dec 07, 2009 7:15 am
<<<Mac Vide Audio Connector.>>>
There is no Mac Vide Audio Connector. Do you have external production equipment connected to your Mac like maybe a FireWire video capture unit or an external digital audio workstation?
I'm going to have to sleep on this one. Maybe Billw58 will have something.
