Hi there.
Basically..
I want to record a sound from a program to audacity. I need to use the recording setting thnig line-in I think (which is what the computor is playing, reocrds what comes out of the speakers).
Then I want to record my guitar and vocas on top, plugging my guitar into computor, and using a mic for vocals.
Im using Windows vista which means I cant record what the computor is playing.
Can someone tell me, in the smplest way possible (seriously, im clueless to anything mildly complex, tell me so a 5 year old can understand) how to make it so I can record what the computor is playing which copyingthe backing and guitar at the same time when I record playing two tracks at once.
Bear in mind my computor has pretty good sound card (I think) and I have no access to taking the computor apart or anything. I wish to spend no money and prefeably not download anything although i think that may be inevitble.
Remeber, im stupid, k?
Thanks!!!!!!!!
If it's any help, i'm using the lastest version of audacity, 1.34 beta or something.
Im stupid.. please help =]
alkalinetrio
Re: Im stupid.. please help =]
Alkalinetrio, you will be more likely to get a response if you post this in the 'Windows unstable' forum above.
Good luck,
Marc
Good luck,
Marc
If you have a few moments, thanks for checking out my songs:
http://www.soundclick.com/bands/pagemusic.cfm?bandID=664656
