I don't seem to have a 'line-in' to record from
eatingrich
Re: I don't seem to have a 'line-in' to record from
Post by eatingrich » Sun Dec 13, 2009 10:13 pm
Hi Dave, that's really interesting - sadly it didn't come with a 'drive' to slot into a bay though, I've not seen it mentioned in any of the reviews of it either - if only it did and it might have solved the problem!
Thanks for posting though, cheers.
Post by steve » Sun Dec 13, 2009 11:31 pm
Do you have "Creative Mixer" installed? It is included in the software for all SoundBlaster cards and has an icon near the time/date (usually also a link in the Start menu).
eatingrich
Post by eatingrich » Mon Dec 14, 2009 9:59 pm
Hmm, not sure I can find that one. Thanks for the pointer.
I had a look on the Creative Audio Console and saw the decoder was set to built-in decoder rather than the S/PDIF decoder, which it says would require an external decoder.
The reason I mention this is that one of the recording options I get on audacity is for a S/PDIF-In. Not sure if it's connected...
Sleepwalker
Post by Sleepwalker » Sat Dec 19, 2009 8:53 pm
Your line in on your sound card should be color coded light blue or blue and then you can activate through your Audacity control panel selector {drop down menu} If your using vista or windows 7 check out this link[url]http://wiki.audacityteam.org/index.php? ... _audio[url] cheers
senga
Post by senga » Wed Dec 23, 2009 11:51 pm
Have you managed to get a line in ?
I've got exactly the same problem as you do...
Post by kozikowski » Fri Dec 25, 2009 1:25 pm
<<<The reason I mention this is that one of the recording options I get on audacity.>>
There are two ways to set Audacity inputs. The quicky way is with the drop-down menus on the work window, but a much better way is with the Audacity Preference panels.
If you're on Vista, there are new rules.
http://forum.audacityteam.org/viewtopic.php?f=12&t=796
