Missing Playback
Gigmeister
Missing Playback
I am using Audacity version 1.26 on my iMac G5 1.8 Power PC. (2 gig RAM, 250 gig Internal, 120 gig and 1 terrabite external HD, OX Tiger system 10.4.11) I can record audio using my Presonus Firebox but am unable to play it back. I keep getting the following:
"error while opening sound advice. Please check the output device settings and the project sample rates. "
I am using 44.1K mono on the Firebox and have it connected as input and output. Any ideas what keeps me from being able to hear my recordings? Thanks in advance.
Re: Missing Playback
Audacity defaults to 32-bit floating and Mono which is an odd combination in anybody's book. Change Audacity preferences o 44100, 16-bit, Stereo and restart Audacity.
Wait. The show is in Mono? It may be just the 32-bit thing.
Gigmeister
Still no dice. I tried mono and stereo and it keeps providing the same message. Any other suggestions?
Did you find the 32-bit setting? That one's famous for causing problems. Preferences > Quality?
Gigmeister
I switched immediately to 32 bit and never had a problem with it before. I do lots of voiceover work and almost all of it is 16 bit, usually 44.1K. I have the standard file set to .aiff since I'm on a Mac. I usually export files that need to be .wav upon mixdown.
Gigmeister
I'm still getting the same error message. Any other ideas? Thanks.
Have you tried Audacity 1.3.9?
Gigmeister
I have not but will download and try it today. I am still on Tiger OS 10.4.11. Will it work with that?
I think it should, but we'll soon find out
