Audacity 1.3.x is now obsolete. Please use the
current Audacity 2.1.x version.
Mac 0S X 10.3 and earlier are no longer supported but you can download legacy versions of Audacity for those systems
HERE.
BobDobbs
Post
by BobDobbs » Tue Nov 24, 2009 11:35 pm
I'm successfully running Audacity 1.3.9b on my G4 laptop, but when I install it on my dual G5 (OS X 10.4.11) it hangs every time.
I have removed all plugins from the library, user library, and Audacity folders. Preferences, old and new, have been trashed. Audacity gets to the first run "select language" dialog and hangs with the pinwheel of death. I have a couple of huge crash log files, which I'll post if desired, but the essential part seems to be:
Code: Select all
Host Name: My-Studly-DP-G5
Date/Time: 2009-11-22 02:04:52.994 -0500
OS Version: 10.4.11 (Build 8S165)
Report Version: 4
Command: Audacity
Path: /Users/greg/Desktop/Audacity.app/Contents/MacOS/Audacity
Parent: Audacity [14814]
Version: 1.3.9.0 (1.3.9.0)
PID: 14816
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_INVALID_ADDRESS (0x0001) at 0x161582f8
Thread 0 Crashed:
0 <<00000000>> 0x161582f8 0 + 370508536
1 dyld 0x8fe029e4 dyld::removeImage(ImageLoader*) + 240
2 dyld 0x8fe08220 NSUnLinkModule + 124
3 libSystem.B.dylib 0x9005e4dc NSUnLinkModule + 96
4 com.apple.CoreFoundation 0x9081edb8 _CFBundleDYLDUnloadBundle + 60
5 com.apple.CoreFoundation 0x907f54b8 CFBundleUnloadExecutable + 188
6 com.apple.CoreFoundation 0x907f533c __CFBundleDeallocate + 44
7 com.apple.CoreFoundation 0x907bed54 _CFRelease + 240
8 com.apple.openscripting 0x930eb868 shlb_entry::Unload() + 96
9 com.apple.openscripting 0x930eb6bc UnloadAllAdditions() + 180
10 libSystem.B.dylib 0x90014978 __cxa_finalize + 260
11 libSystem.B.dylib 0x90014844 exit + 36
12 net.sourceforge.audacity 0x0003a424 std::_Deque_base<Response, std::allocator<Response> >::~_Deque_base [not-in-charge]() + 138548
13 net.sourceforge.audacity 0x0003a124 std::_Deque_base<Response, std::allocator<Response> >::~_Deque_base [not-in-charge]() + 137780
Thread 0 crashed with PPC Thread State 64:
srr0: 0x00000000161582f8 srr1: 0x100000004200d930 vrsave: 0x0000000000000000
cr: 0x24002224 xer: 0x0000000000000000 lr: 0x000000009005e6d8 ctr: 0x00000000161582f8
r0: 0x00000000161582f8 r1: 0x00000000bffff780 r2: 0x00000000a0001fa4 r3: 0x0000000001922f90
r4: 0x0000000000000000 r5: 0x00000000000003e8 r6: 0xffffffffffffffff r7: 0x000000000000004c
r8: 0x0000000000000054 r9: 0x0000000000000000 r10: 0x000000005e5e4b48 r11: 0x00000000a00061ec
r12: 0x00000000161582f8 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000
r16: 0x0000000000000000 r17: 0x0000000000000000 r18: 0x0000000000000000 r19: 0x0000000000000000
r20: 0x00000000a000487c r21: 0x00000000a000487c r22: 0x00000000a0001fa4 r23: 0x0000000000000000
r24: 0x0000000016642000 r25: 0x0000000001922f90 r26: 0x0000000016642000 r27: 0x0000000000000000
r28: 0x0000000000000000 r29: 0x0000000001900030 r30: 0x00000000161582f8 r31: 0x000000009005e514
I tried 1.3.10 (latest nightly) and have the same problem. Anything I can do to try to isolate this further?
billw58
Post
by billw58 » Wed Nov 25, 2009 12:02 am
BobDobbs wrote:I'm successfully running Audacity 1.3.9b on my G4 laptop, but when I install it on my dual G5 (OS X 10.4.11) it hangs every time.
I've successfully run 1.3.9 and 1.3.10 on a dual G5 with both 10.4.11 and 10.5.8.
Check /Library/Audio/Plug-ins/VST and ~/Library/Audio/Plug-ins/VST to make sure there are no VST effects lurking there.
How did you get out of the pinwheel of death? A Force Quit doesn't usually produce a crash log.
-- Bill
BobDobbs
Post
by BobDobbs » Wed Nov 25, 2009 12:22 am
Nope, checked all the plugin directories in root and user paths - all empty.
I did have to force quit, but somehow I did get a log. Not every time, though.
Oh, and I disabled startup stuff like "Default Folder X" just in case. Made no difference.
billw58
Post
by billw58 » Wed Nov 25, 2009 1:24 am
I've posted your report and crash log to the developers' list. Hopefully someone there will be able to decipher what is going on.
-- Bill
billw58
Post
by billw58 » Wed Nov 25, 2009 2:35 am
I just noticed that you're running Audacity from the Desktop. Are all the other folders that Audacity needs also on the Desktop, like "Languages", "Nyquist" and "plug-ins"?
I usually run Audacity from a folder in Applications so I can keep all that stuff next to Audacity.
-- Bill
Leland
- Developer
Post
by Leland » Wed Nov 25, 2009 2:43 am
Hi Bob,
Can you try the latest nightly build at:
http://audacity.homerow.net/index.php?dir=mac
I think you're problem "may" have already been resolved.
Thanks,
Leland
billw58
Post
by billw58 » Wed Nov 25, 2009 3:16 am
billw58 wrote:I just noticed that you're running Audacity from the Desktop. Are all the other folders that Audacity needs also on the Desktop, like "Languages", "Nyquist" and "plug-ins"?
Never mind, Audacity runs just fine from the Desktop. Just no choice but "English" in the First Run dialog, and no Nyquist effects.
-- Bill
BobDobbs
Post
by BobDobbs » Wed Nov 25, 2009 5:36 am
I tried running it from the desktop because I've seen some applications have problems if they're too deep in the directory tree - but it seemed to make no difference. Like just now I tried with all the plugins installed, and got the same symptoms. I rebooted the Mac, ran that latest build of Audacity 1.3.10 before I launched any other apps... hang. I did not get a trace in the console logs the last 3-4 times I launched Audacity, either.
It shows "not responding" in the Activity Monitor.
Sorry... there must be something I'm not doing. I installed 1.2.4 again, and it runs fine. Checking to see if maybe something wasn't getting created by 1.3.x when it ran, I switched to 1.3.10 again, and it still hangs. I'll keep trying to work out a set of conditions that allows it to run and let you know if I get something to work...
Post
by kozikowski » Wed Nov 25, 2009 4:01 pm
Did you try anything earlier? Around 1.3.8/9 was the first time Audacity used a new and different technology for managing add-ons and plug-ins. I do production in 1.3.7 on multiple machines with good stability, but have had troubles with later issues.
It would be an interesting event if the machines suddenly started working.
It would be entirely fascinating if they didn't.
BobDobbs
Post
by BobDobbs » Wed Nov 25, 2009 4:25 pm
I am dl'ing 1.3.7 at this moment. Can't install it till I get home, but I'll report asap on the results. Thanks!
