audacity wrote:In the Audacity project rate tool bar, could you display more precise file properties, for instance:MPeg1.0 Layer3 -128 kps - 44khz - joint stereo (Player decoder ACM)
Once an audio file has been imported into Audacity it is not an mp3. Audacity uncompresses the file so that it can be processed.
The "Project Rate" is not a reference to the original file but to the default sample rate that is used in the current project. All files, no matter which will be played at the project rate, and exported at that rate. Should the sample rate of a track be different from the Project Rate, these tracks will be resampled to the Project Rate as the project is played back or exported.
The project rate can be changed by clicking on that number and selecting another from the drop-down menu.
Since Audacity supports multiple tracks, and the tracks may include samples from different sources, it is more meaningful to display the project rate than the original format of the source file. You can find the properties of the source file by right clicking on the file and selecting "Properties > Summary"
