Entering "k" in labels scrolls WAV panel
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
RodBarnes
Post by RodBarnes » Tue Nov 24, 2009 3:19 am
Odd thing. I was typing an entry into a label (it is still up on my screen). I entered "Than" then typed "k" and the wave panel scrolls all the way to the right!? If I type the next character (space), the "k" does not appear but the space does and I can continue typing. If I cursor back to try and enter the "k" again, it repeats the behavior (scrolls the wave panel all the way to the right). It absolutely refused to allow me to enter a "k". I had to enter the text elsewhere an then paste it in to get it correct.
Running Vista x64, nVidia 9800 GT, double monitor.
billw58
Re: Entering "k" in labels scrolls WAV panel
Post by billw58 » Tue Nov 24, 2009 4:40 am
Which version of Audacity are you using? This is a known bug (the "k" key is the shortcut for move cursor to end of track), but AFAIK it has not been seen in 1.3.9.
-- Bill
RodBarnes
Post by RodBarnes » Tue Nov 24, 2009 5:14 am
Testing version 1.3.9. I did search for something trying to see if this was already known but didn't find anything in my search.
Post by steve » Tue Nov 24, 2009 5:31 am
The issue is listed as a "P3" in the "Release Checklist http://wiki.audacityteam.org/index.php? ... _Checklist
The note that accompanies it is:
"Not reproducible to order, but very likely to occur with large numbers of labels in a track. Once it occurs, typing "j" or "k" in any label in that track will move the cursor to start/end of the track."
(I've not seen this problem myself, but I rarely use many labels).
RodBarnes
Post by RodBarnes » Tue Nov 24, 2009 5:34 am
FYI: In one instance, I had this happen on the 7th label entry but it did not happen on the 2nd label entry. In another, it happened on the 3rd and subsequent labels.
billw58
Post by billw58 » Tue Nov 24, 2009 8:26 pm
As this bug is "not reproducible to order" it's been hard to track down.
As a work-around, go to Preferences > Keyboard and either set different shortcuts for the commands that use the J and K keys without a CTRL or ALT modifier (there are four of them under the "Edit" category - SHIFT+J, SHIFT+K, J and K), or, if you don't use those shortcuts, just clear them.
-- Bill
RodBarnes
Post by RodBarnes » Tue Nov 24, 2009 9:13 pm
billw58 wrote:As this bug is "not reproducible to order" it's been hard to track down.
Would it help to have a particular file with which this occurs and the steps to reproduce it? I have steps where I can cause this to happen every time in v1.3.9 regardless of the WAV I import:
  • Open Audacity
    Drag in a WAV
    Wait it to be rendered
    Go to the start of the waveform
    Type Ctrl-B to create a label
    Enter "thanks"; press Enter when complete.
    Press backspace, then Ctrl-Z
    Click at any point in the waveform.
    Enter "thanks"; or try to, anyway. :?
billw58
Post by billw58 » Tue Nov 24, 2009 9:23 pm
  • Open Audacity
    Drag in a WAV
    Press backspace <- this deletes the wav and label tracks if "Select all audio in project, if none selected" is checked in Tracks Preferences. Otherwise, if "Select all audio in project, if none selected" is not checked, nothing happens
    then Ctrl-Z <- only needed if tracks were deleted
    Enter "thanks"; or try to, anyway. :? <- works for me, no trouble entering the second label
-- Bill
RodBarnes
Post by RodBarnes » Tue Nov 24, 2009 11:46 pm
billw58 wrote:works for me, no trouble entering the second label
Well, it was worth a try. It happens every time on my system.
RodBarnes
Post by RodBarnes » Thu Nov 26, 2009 4:53 pm
I have confirmed a case where the "K" and "J" key issues occur without having linked tracks (see attached). However, I also found that when I selected "View -> Fit Vertically", the problem disappeared.
Just more data to help isolate the problem.
Unlinked K-J issue.JPG (52.32 KiB) Viewed 2077 times
