Reverb
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
rj7500
Reverb
Post by rj7500 » Wed Nov 18, 2009 4:35 pm
Is it possible to add reverb to a given track on the Beta version?
Thanks
Bob
billw58
Re: Reverb
Post by billw58 » Wed Nov 18, 2009 4:48 pm
Yes, but you'll need to find and install a 3rd party reverb plug-in. What you use will depend on what operating system you have.
-- Bill
Re: Reverb
Post by kozikowski » Wed Nov 18, 2009 6:26 pm
Freeverb and GVerb seem to be pretty popular.
GVerb seems to come with 1.3.7. I can't tell if that's a platform specific thing.
billw58
Re: Reverb
Post by billw58 » Wed Nov 18, 2009 9:00 pm
Both Gverb and Freeverb are difficult to get a good sound out of. Perhaps that is why they are no longer included with 1.3.9. I did a search for a decent Mac-compatible free reverb plug-in a few months ago and came up with two. But if the OP is on Windows there may be more choices, and if on Linux fewer choices.
-- Bill
Re: Reverb
Post by steve » Wed Nov 18, 2009 10:06 pm
I prefer Freeverb to G-verb, but both are capable of decent results with a bit of tweaking. I would definitely recommend applying "wet" reverb to a duplicate of the track, then mixing the original (dry) track with the reverb (wet) track, rather than trying to guess the wet/dry mix. I find that both these reverbs tend to be rather too bright, but that can be tweaked by using Eq on the "wet" track.
For Linux (in no particular order):
Freeverb
G-Verb
TAP Reverberator
Calf reverb
Impulse convolver
g2reverb
Jconv
Sox reverb
Invada LV2 reverb
Not all of these are fully compatible with Audacity, but the first 4 definitely are, and SOX definitely isn't (it's a command line program).
rj7500
Re: Reverb
Post by rj7500 » Thu Nov 19, 2009 3:51 am
Hey all, thanks for the quick response. I know I'll always get that from this forum.
I'm using WindowsXP Media Edition (don't giggle, it came with the desktop) and the Beta 1.3 of Audacity
billw58
Re: Reverb
Post by billw58 » Thu Nov 19, 2009 5:40 pm
Have a look at this page:
http://wiki.audacityteam.org/index.php?title=GVerb
That page also has recommendations on other reverbs. Personally I like the Anwida Soft DX Reverb Light.
-- Bill
Re: Reverb
Post by steve » Thu Nov 19, 2009 6:27 pm
billw58 wrote:Personally I like the Anwida Soft DX Reverb Light.
+1
rj7500
Re: Reverb
Post by rj7500 » Wed Dec 02, 2009 2:14 pm
I downloaded the DirectX version of Anwida DX Reverb Lite, however I'm not quite sure how to interface it with Audacity. I see no reference to it in any of the Audacity menus.
Bob H
Irish
Forum Crew
Re: Reverb
Post by Irish » Wed Dec 02, 2009 3:38 pm
You need the VST version, in order for it to work with Audacity. - Use the VST version download link for Windows, in the wiki page that Bill linked to.
Extract the .dll file from the .zip and put it in Audacity's Plug-Ins folder (C:Program FilesAudacityPlug-Ins). It will appear in the Effect menu, below the horizontal line.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
