Set to Stereo, but playing back in mono (will only pan left)
This section is now closed
jmeyers
Post by jmeyers » Tue Nov 10, 2009 9:32 pm
Hello,
New to Audacity. Been recording in stereo just fine, but after a few hard crashes with Audacity, it stopped recording in stereo. Even though it's set to record in stereo in preferences and the channel says it's stereo, there's only one channel showing any sound frequency. Won't even let me pan to the right, just hard left.
Anyone give me any pointers on this?
Much appreciated.
Re: Set to Stereo, but playing back in mono (will only pan l
Post by steve » Tue Nov 10, 2009 10:00 pm
Are you sure the recording source (the thing you are trying to record) is OK?
What is the recording source?
jmeyers
Post by jmeyers » Tue Nov 10, 2009 11:20 pm
I am recording with the same instruments that recorded in stereo fine before the crash. Using several different keyboards, all of them are recording only left-mono. I can copy one channel, split it and paste it then recombine it as stereo, but that's pretty arduous.
Post by kozikowski » Tue Nov 10, 2009 11:32 pm
You may have seriously scrambled preference files. Close Audacity and trash the configuration(preference) files.
Trash Mac Audacity Preferences
http://audacityteam.org/forum/viewtopic ... =10#p34670
When you restart Audacity, it should ask you "English?" and that's your confirmation that you're starting fresh. Then immediately go into Audacity preferences and reset to 44100, 16-bit, Stereo. Restart Audacity.
Then try to record something.
You actually don't need to go into full-on record. Click once inside the red Audacity record meters and they will wake up and meter your sound without going into record.
Do you know why it crashed?
Apple > About This Mac > Processor and Version. Read both, please.
jmeyers
Post by jmeyers » Wed Nov 11, 2009 4:08 am
Version 10.5.4
2.5ghz core 2 duo
4gb ram
Post by kozikowski » Wed Nov 11, 2009 6:02 am
Leopard/Intel. Cool. There is no stable Audacity 1.2 for us. Your program will do weird and wacky things as long as you continue to use it.
I use 1.3.7 from here...
Audacity 1.3.7 -- Mac
http://audacity.googlecode.com/files/au ... -1.3.7.zip
...for all my production.
Or, you can go with with the latest download...
Audacity Current Release -- Mac
http://audacityteam.org/download/beta_mac
...although there are instances of people needing to go to the 1.3.10 nightly builds to get a stable program. 1.3.7 is good.
jmeyers
Post by jmeyers » Wed Nov 11, 2009 5:40 pm
Man, thanks! Limited audio software for Macs, at least affordable or shareware. I'll let you know how it works.
jmeyers
Post by jmeyers » Wed Nov 11, 2009 10:14 pm
Downloaded the version you have and it's still recording in mono hard paned to the left.
Post by steve » Wed Nov 11, 2009 10:20 pm
Did you reset the Audacity Preferences?
Did you get prompted to select "English"?
On OS X the preferences are stored in a file called "audacity.cfg" which is located in: ~/Library/Preferences/audacity Preferences
crusty
Post by crusty » Thu Nov 19, 2009 8:53 pm
Hey there,
I am having the same problem.Tried downloading latest beta version - still doesn't work.
Did you find a solution jmeyers?
Cheers
