Save Project
roy windmill
Save Project
Hi, After recording an L.P in Audacity 1.3.9, I clicked File-save project, and had a warning that I am saving a file only Audacity can open, and an O.K tab to click. Now I can only open the file in W.M. Player. When I click File-Open I have a Audacity (R) icon, and a File Name_data folder. I don't want to lose my recording. Can I still edit and Export Multiple? I have Windows XP. Many thanks, Roy
Re: Save Project
What you have saved is an Audacity project, and no other program will open it.
Select the project file and your project will open.
PO'L
In the File window that you get when you select File > Open, the file with the Audacity icon is the Audacity project file, (it should have the name that you gave your project when you saved it) and the _data folder contains all the audio data.roy windmill wrote:When I click File-Open I have a Audacity (R) icon, and a File Name_data folder.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
roy windmill
Re: Save Project
Hi Irish, Thanks for your help. I am able to continue now. Roy Windmill
