music intro to pod cast
heinco
Post by heinco » Sat Oct 31, 2009 9:57 pm
10/31/09
Hi:
I've selected a brief classical segment and would like to get it from Itunes to audacity to use a portion for an intro to then fade out at the beginning and fade in at the end of the pod cast. Please direct me to a procedure for getting the mp3 onto audacity.
Many thanks!!
Heinco
billw58
Re: music intro to pod cast
Post by billw58 » Sat Oct 31, 2009 10:11 pm
If you're using Audacity 1.2.x, the command is "Project > Import Audio".
If you're using Audacity 1.3.x, the command is "File > Import > Audio".
-- Bill
heinco
Post by heinco » Sat Oct 31, 2009 10:25 pm
Many thanks for the really quick reply.
I may be back to you in that I'm not a technical person, but have a great interest in Pod Casting.
Many thanks,
Heinco
billw58
Post by billw58 » Sat Oct 31, 2009 10:28 pm
heinco
Post by heinco » Sat Oct 31, 2009 10:37 pm
Hi again Bill:
This article looks exactly like the solution. We're taking a dinner break with a few grandchildren, but will be back at it shortly.
I'm very, very grateful for your interest in helping me to find solutions.
Many, many thanks,
Paul (heinco)
heinco
Post by heinco » Sun Nov 15, 2009 1:38 am
Help!!!!
I have a music intro and have a voice content. We want to have a music intro that fades, which we've mastered.
I'm missing something. How do I simply put a music intro before the voice interview content?
Also, music at the end that fades after the voice content.
Help!!!
Heinco
[email protected]
billw58
Post by billw58 » Sun Nov 15, 2009 1:41 am
http://manual.audacityteam.org/index.ph ... ound_Music
Note that this applies to 1.3.x. What version of Audacity are you using? It will make a difference as to what features are available.
-- Bill
heinco
Post by heinco » Sun Nov 15, 2009 1:56 am
Bill:
we have 1.2.6
Paul
billw58
Post by billw58 » Sun Nov 15, 2009 2:12 am
heinco wrote:Bill:
we have 1.2.6
Paul
OK, so that link won't do you much good.
heinco wrote: I have a music intro and have a voice content. We want to have a music intro that fades, which we've mastered.
[email protected]
You can't do that in 1.2.6. You'll need separate tracks for the music intro, voice bit, and music extro. You can slide each track left and right to line up where you want, but you can't have separate clips on each track. It's actually more flexible that way, as you can have the voice begin just slightly before the music fades out, and have the extro music begin to fade up during the end of the voice segment.
When you finally export the project, Audacity will mix everything down into one MP3 (or AIF - whatever you choose) file exactly the way you hear it when you play it back.
You might want to look into installing 1.3.9. You can have both versions on your machine without conflicts, you just can't use both at once. And 1.3.9 projects can't be opened in 1.2.6.
-- Bill
heinco
Post by heinco » Sun Nov 15, 2009 2:30 am
Just. Upgraded to the 1.3 version.
Paul
