On some of my songs the sound is higher or lower. How cam I get the sound to remain the same for all recordings if that is possible
Thanks in advance
How to have sound remain equal
Re: How to have sound remain equal
Hmm... depends on what are you meaning (your self recorded music or music ripped from CD/LP/Cas) but, maybe applying normalize (or amplify) effect for each track helps in this.
Juha
Juha
When I play back some of the music one cd might have higher sound that others, btw these are tunes I have d/l from the internet .
Thanks
Thanks
Assuming they all open up in Audacity, you can use Effect > Amplify on each one before you mix them together.
That's the quick and dirty version. That doesn't process loudness, but it does make the blue waves line up more or less, and that's usually enough.
If you like to change the character of your show -- like bopping back and forth between music and talking, then Chris' Compressor is pretty much the only automated tool left.
http://pdf23ds.net/software/dynamic-compressor/
That one does process loudness, but it has the same effect as running your show through FM radio station processing... everything comes out flat and the same volume. Try it.
Thanks, I give that a try
