Windows 7 and Audacity query
Edgar
Forum Crew
Re: Windows 7 and Audacity query
Post by Edgar » Sat Nov 07, 2009 5:36 pm
theAM89 wrote:Hi,
I have a problem with the Trust 5.1 External Surround Sound Card SC-5500p, downloaded the 14134 driver for w7, but during install it asks to plug-in Trust USB Audio device. It is pluged, tried all ports, but nothing changed. Before the w7 driver was released, only 2 speakers and sub were working(windows installed some driver itself - I disabled them when installed 14134).
It would be great if somebody could help me with this problem.
AM
(windows 7 EC build 7100)
Generally, when installing a USB driver the device itself must NOT hooked up to the computer while the driver is being installed. Try unplugging your external sound pod's USB cord from the computer and reinstalling the driver only plugging in your device when it asks you to.
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
happy37
Post by happy37 » Sat Nov 07, 2009 9:35 pm
Gale Andrews wrote:
happy37 wrote:I have been told by ASUS, the motherboard manufacturer that there are no up-to-date drivers for the souncard and the motherboard as it was discontinued quite a while ago.
1. Unless someone else can find me a working (stable) Vista or Windows 7 driver that they have used and it works well on their PC, I would be very woilling to try that out as well to see if and how it works.
2. Otherwise, can you please recommend me a decent PCI soundcard that I will be able to use with this motherboard, please?
The motherboard is an ASUS P4PE:-
http://support.asus.com/download/downlo ... model=P4PE
If you are buying an add-on card, compatibility with the motherboard is rarely an issue, only with the operating system.
I don't have any experience myself with PCI cards. If you go for one, look for explicit information about Windows 7 compatibility. If your main concern is capturing the audio output, I would go for this USB card:
http://www.trust.com/products/product.aspx?artnr=14134
It is compatible with Windows 7 and it does capture computer output (called "Sum"). You haven't given us an example of a Windows 7 recording, but if noise from inside the computer could be a problem, an external solution like this might be better.
Hi Gale et al...
Good evening - can you please let me know when or how soon Audacity 1.3.9 beta will be released as Audacity 2.0 (stable) for Windows 7?
Thanks...
Happy37
Post by Gale Andrews » Sun Nov 08, 2009 1:04 am
happy37 wrote: can you please let me know when or how soon Audacity 1.3.9 beta will be released as Audacity 2.0 (stable) for Windows 7?
We're aiming to release 2.0 around 1st December. It may not necessarily support Windows 7 fully, as we are lacking developers at the moment to work out some problems on Windows 7 and Vista. However even if full support is announced, it won't help the case where no suitable drivers for the inbuilt sound device can be found.
Sgtbobert
Post by Sgtbobert » Sun Nov 08, 2009 1:51 am
I just got windows 7 installed on my desktop and discovered that I can no longer record audio from my computer. Before when I used vista I remember going to the Recording tab of the sound settings and making one the devices default and I would be able to record sound from my speakers. However I can no longer do this. The only thing that remotely looks like it should be recording the sounds coming from my computer is called "Digital Audio (S/PDIF)" I don't know if this is what records sound now or if it was removed from my computer. I use a Pinnacle HD TV Tuner 800i to record video and I think this is what I used to record the sound. Windows update installed the drivers but I am still not able to record sound. I'm aware that this question may have been asked already but I can't find an answer to my problem.
Post by steve » Sun Nov 08, 2009 7:43 pm
Sgtbobert wrote:Before when I used vista I remember going to the Recording tab of the sound settings and making one the devices default and I would be able to record sound from my speakers. However I can no longer do this.
Have you set it to show Disabled and Disconnected devices? http://wiki.audacityteam.org/index.php? ... ng_devices
Edgar
Forum Crew
Post by Edgar » Sun Nov 08, 2009 7:58 pm
Sgtbobert wrote:I just got windows 7 installed ... I use a Pinnacle HD TV Tuner 800i ... Windows update installed the drivers...
I just installed the release version of Windows 7. It "installed the drivers" for my built-in SoundMax audio but the drivers it installed were three years out of date. I went to the manufacturer's site and downloaded the most current driver (had to use the Vista 64-bit as they did not list a Windows 7 driver). I also have a AudioFire4 external FireWire sound pod; Windows 7 did not install any drivers for it (as I expected) but I chose this device because it was known to have excellent 64-bit Windows 7 drivers which I install.
I strongly suggest that you go to the Pinnacle site and download the most recent Windows 7 (or Vista if Windows 7 is unavailable) driver in 32-bit or 64-bit as appropriate. Even if it looks like it is the same driver you might want to try and reinstall it, just for luck.
-Edgar
