Changing default program association
will7ns
Post by will7ns » Fri Oct 16, 2009 11:53 pm
How can I configure Audacity to save wav files to Winamp (it currently saves to Musicmatch Jukebox)?
Thanks.
Irish
Forum Crew
Re: Changing default program association
Post by Irish » Sat Oct 17, 2009 7:48 am
It's not Audacity doing that. It's Windows.
Audacity will export your WAV file as a WAV file; end of story.
In Windows, your File Association seting is automatically opening WAVs in Jukebox.
To change this, in Windows Explorer, right-click on any WAV file, select 'Open With' and you should get a list of programs to choose from. You should also get a 'Choose Default Program' or 'Choose Program' option and a check box that says 'Always use the selected program to open this type of file'
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
