cannot start audacity in opensuse 11.2
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
dutchkind
Post by dutchkind » Fri Oct 16, 2009 9:20 am
When I try to start audacity 1.3.8 in opensuse 11.2 rc1 I get the dialog to select the language, and then nothing. Starting audacity from command line gives me the following:
audacity: simple.c:585: snd_mixer_selem_get_capture_volume_range: Assertion `(elem)->type == SND_MIXER_ELEM_SIMPLE' failed.
Aborted
Is there a way to fix it? Could I give an option on the command line to circumvent the problem?
Opensuse 11.2 rc1 x86-64 with 3Gb ram, kde 4.3.1
Re: cannot start audacity in opensuse 11.2
Post by steve » Thu Oct 29, 2009 10:13 am
If you are able to build Audacity from source...
download the latest source code
delete the hidden folder /home/<username>/.audacity_data
(make sure that you get no errors about missing dependencies)
dinosaur
Post by dinosaur » Mon Nov 30, 2009 5:25 pm
Hello,
I have a similar setup. I just used the YAST tool and installed 1.3.9-17 from Suse. Everything worked fine. I got an idea that some of the dependencies from "Flash Player" might be involved though as "Flash Player" installation wouldn't allow audacity to work in Ubuntu 8.04. There I could install one or the other but not both at the same time.
