Bluetooth - output device fails
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
colbec
Post by colbec » Sat Oct 10, 2009 12:27 pm
I'm running OpenSuse 11.1 and bluetoothd with Blueman. Hardware is a Jabra BT2040 connecting to an MSI Starkey USB.
Recording with arecord works (even though arecord -l does not list the device), and playback of that file with aplay works through the headset.
Now to Audacity. I can specify the headset as input and output device, record works (but quality is quite poor), but output fails with "Error while opening sound device" - sample rate is 8000.
aplay of the same file works fine.
Any thoughts?
colbec
Re: Bluetooth - output device fails
Post by colbec » Sat Oct 10, 2009 8:29 pm
FWIW the output device info from Audacity is:
Device ID: 9
Device name: ALSA: jabraj
Input channels: 1
Output channels: 1
Low Input Latency: 0.064000
Low Output Latency: 0.064000
High Input Latency: 0.256000
High Output Latency: 0.256000
Supported Rates:
No info here on rates?
Post by steve » Mon Oct 12, 2009 2:13 am
Do you know what rates the Jabra BT2040 supports? (from the Jabra BT2040 specifications)
Are you really using the 1.2.x version of Audacity?
colbec
Post by colbec » Mon Oct 12, 2009 5:20 pm
My error, wrong forum, using 1.3.8 - should I repost there, or can the post be moved?
The manual for the headset does not say anything about rates. I just assumed that it would be very low. I will try some more.
Reason: Moved to 1.3 section of forum
colbec
Post by colbec » Fri Dec 04, 2009 7:34 pm
Just to update this issue, it all came down to the bluetooth dongle. This appears to be a critical component. If it is weak you can ship software with it that bypasses the weakness but it is still a weak dongle.
I now have a couple of others, a generic and a Belkin. Both of these work with my headsets in linux and in audacity.
