Put onto a CD
kickharze
Put onto a CD
Post by kickharze » Wed Nov 07, 2007 11:40 am
Please help I am new to this.
I have worked out how to edit a track on audacity but how do I now put it onto a cd????
Any help will be welcomed. Thank you
Re: Put onto a CD
Post by kozikowski » Wed Nov 07, 2007 3:19 pm
If you mean make a music CD, then you need an authoring program. Windows Media 11 can burn a music CD, but if you don't have that, you need to buy an authoring program. I use Easy CD Creator and Nero Burn and one other I can't think of the name.
You can use Windows iTunes.
waxcylinder
Re: Put onto a CD
Post by waxcylinder » Wed Nov 07, 2007 3:21 pm
Export it as a WAV file - or a multiple set of WAV files if you have multiple tracks (for multiple tracks create labels including one at the begiining for the first track - and use Aydacity's Export Multiple)
Then use you CD burning software to create a music CD not a data CD - and do use good quality CD-R discs not CD-RW. You should have got a CD burner software package with you PC when it came (if you have a CD burner h/w that is). Dells tend to come with RecordNow - Nero is another popular package.
Edit: and as Koz says iTunes will do the job for you - and it's good at producing CD covers and inserts with track-listings and artwork.
JeffB
Re: Put onto a CD
Post by JeffB » Thu Nov 08, 2007 9:24 pm
