Latency problem recording
lennymusician
Post by lennymusician » Thu Oct 01, 2009 10:46 am
hi all,
Audacity going well but I have a problem recording my keyboard on a new track, there is a slight delay between key being pressed and the noise I hear, any help here most greatfull
Thankyou
Re: Latency problem recording
Post by steve » Thu Oct 01, 2009 5:02 pm
The best solution is to monitor your keyboard directly (before it goes into your computer - for example from a headphone socket on the keyboard).
If this does not help, you will need to give a lot more detail about your set-up (what sort of computer/OS/keyboard/what's connected to what...)
lennymusician
Post by lennymusician » Sat Oct 03, 2009 9:12 am
oh thanks for the tip, will try this
jademan
Forum Crew
Post by jademan » Fri Oct 09, 2009 5:46 am
lennymusician wrote:hi all,
Thankyou
lennymusician,
There is a discussion of latency in the new 2.0 manual page, Latency Test.
As Steve indicates,
stevethefiddle wrote:The best solution is to monitor your keyboard directly...for example from a headphone socket on the keyboard)
I hope this helps.
Post by steve » Fri Oct 09, 2009 2:26 pm
jademan wrote:There is a discussion of latency in the new 2.0 manual page, Latency Test.
Link does not work -
it's here: http://manual.audacityteam.org/index.ph ... tency_Test
