"Judicious Sequencing"
Ito
Post by Ito » Wed Sep 30, 2009 3:22 am
Hey,
is there a way to synchronize a guitar part to a drum track in perfect time?
Like, is there some feature in Audacity or some other program that is - "stretch to measure", or some such?
Thanks!
jademan
Forum Crew
Re: "Judicious Sequencing"
Post by jademan » Mon Oct 05, 2009 4:14 am
Ito,
There is no automatic way of doing this that I am aware of.
If you have a previously recorded drum track and you are playing that track while recording a second, a good idea is to have at least a short drum intro and start playing during that intro. Using the time shift tool, manually line up the two tracks on the beat before you are supposed to come in.
If the two tracks slowly drift apart, you can use change speed or change tempo to correct.
I hope this helps.
Post by steve » Mon Oct 05, 2009 5:08 pm
There are tools to help with that in some expensive music programs such as Sonar and Cubase Studio, but they only really work if the tracks are already pretty close (they can automatically adjust the odd beat that is slightly off, but can't do anything with tracks that are a long way out).
Programs like Recycle (Propellerhead) can handle much more dramatic time stretching with a technique called "beat slicing".
There is also a free program based on / inspired by Recycle called Freecycle, but I think that it is only available for Linux.
As jademan suggests, if you allow yourself a good count in and use some sort of "click track", then with a bit of practice you should be able to get it fairly close, then use a bit of manual tweaking to tighten it up if necessary.
Audacity 1.3 has a click track generator that you may find useful.
Ito
Post by Ito » Tue Oct 06, 2009 7:51 am
thanks guys,
i just bought Sony acid Music Studio 7.0.
it has this sort of grid system where it lines and syncs up tracks, like a graph almost for good timing.
it also has this "Beatmapping" feature for same such...
I recommend it.
many features, requires study.
oh and its cheap - u can get it for $38! online.
Post by steve » Tue Oct 06, 2009 7:12 pm
How could I forget Acid :D
"Acid" has been been at the forefront of sample sequencing for a long time (and a long time before it got the "Sony" prefix). It's good to see it priced at a reasonable consumer level, but a shame that it's Windows only. The Pro version is in a similar "expensive" bracket as the other software that I suggested (and it's the Pro version that has the full time stretching features), but Acid Studio still looks to have a good range of features.
I think that you will find that beatmapping works perfectly with "Acidized" samples, but is rather less effective with recordings, but let us know how you get on.
jademan
Forum Crew
Post by jademan » Thu Oct 08, 2009 1:21 am
Ito,
Also check out this page from the new 2.0 manual which was just finished today: Latency Test
Ito
Holy Moley!
Post by Ito » Thu Oct 08, 2009 3:33 am
i just downloaded "GunGirl" audio sequencer (freeware).
This thing rocks!
its got a timestretch.
and the program is so small and versatile - that makes it all the more powerful!
ya gotta check it out
http://www.hitsquad.com/smm/programs/GungirlSeqWin/
Post by steve » Thu Oct 08, 2009 3:57 pm
There's even an on-line audio sequencer called Myna :o . It is a Flash application. http://aviary.com/tools/myna
