wav file distortion
suzanne
wav file distortion
Post by suzanne » Tue Sep 22, 2009 10:55 pm
I am using Audacity to edit narration only (no music). When I modify a wav file and export it as a new wav file, it becomes completely distorted and static-sounding. If I export as mp3 it sounds fine. I prefer wav files for my project. Is something happening to the bitrate or another feature? This is a recent problem, probably in the last month or so. I have used Audacity successfully on this machine for wav files for almost a year until now.
billw58
Re: wav file distortion
Post by billw58 » Wed Sep 23, 2009 1:02 am
suzanne wrote:This is a recent problem, probably in the last month or so.
Suzanne:
Can you think of anything that has changed on your computer in the past month? Upgraded to a new version of Audacity?
Also, in order to help you, we need to know the Audacity version, PC specs and OS version.
-- Bill
suzanne
Post by suzanne » Wed Sep 23, 2009 4:35 pm
Because this happened last week I uninstalled and reinstalled the software but it is still the same version, 1.2.6 I think? I have a Dell PC with XP. Are there other computer specs you need? I have not changed anything else with the computer recently. Is it necessary to work on the hard drive as opposed to an external hard drive? Thank you!
Trebor
Could attach a short sample of the distorted wav
Post by Trebor » Wed Sep 23, 2009 6:13 pm
It is possible to attach a few seconds of a wav to a post if it is put in a zip file, (example attached).
If a short (~5sec) example of the distorted wav was posted (in a zip) it may help identify the cause.
Countdown from five to zero.zip
(499.17 KiB) Downloaded 72 times
suzanne
Post by suzanne » Thu Sep 24, 2009 5:31 pm
Thanks Trebor, attaching a zip file with a 2 second audio clip. I tried for 5 seconds but it was too big. Interestingly, when I play this on windows media player they sound fine. But when I try to import it into PPT using Articulate, it sounds completely distorted. I have other audio files that I edited in Audacity on my computer at work and they are fine both in WMP and Articulate. Any ideas?
Slide01_title_test_2.zip
(259.09 KiB) Downloaded 59 times
Post by kozikowski » Thu Sep 24, 2009 6:17 pm
Audacity defaults to 44100, 32-bit floating, Mono when it wakes up the first time. That can cause problems because not all applications know how to handle 32-bit.
Change Audacity preferences to 44100, 16-bit, Stereo.
You can right-click > Get Properties > Advanced on one of your files and it may tell you what the sound standards are. You can try to convert one of your "broken" files by changing the bit depth.
http://forum.audacityteam.org/viewtopic ... 190#p41629
Post by kozikowski » Thu Sep 24, 2009 6:18 pm
The sample you sent is in 32.
Trebor
There are different types of WAV
Post by Trebor » Thu Sep 24, 2009 6:58 pm
I used a codec analyser thingy (not an Audacity feature ) on your sample and this was the result ...
The "float"ing point bit is why your sample is only playable on some devices.
When you save ("Export") a file as a WAV, select a WAV format which does not have the "float" bit ...
Don't save WAV as 'float', save as 32bit (or 16bit) 'signed'.png (37.81 KiB) Viewed 2470 times
Post by kozikowski » Thu Sep 24, 2009 8:37 pm
Because of where you posted, we don't know which version of Audacity you have. If you have 1.3 +, you can set the export specifications at export. If you're on 1.2, you will need to set it in Audacity Preferences and then restart Audacity.
I don't remember there being a 32-bit non-floating option.
Let us know if that worked. We've been telling people to use 16-bit to get around this.
suzanne
Post by suzanne » Tue Sep 29, 2009 6:48 pm
I was definitely on an older version, so I set the preference and then restarted Audacity. I tried both 16-bit, and 32-bit signed and they both worked! I guess it was the default setting of "32-bit float" that was causing the trouble. Many thanks to everyone who contributed!
