Audacity 1.39 problems with VST plugins, 1.38 is fine..why?
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
takm
Post by takm » Thu Sep 17, 2009 7:35 pm
I'm using Windows 7, and while using audacity 1.39, i found that it didn't find some of the VST plugins i have installed. But if i downgraded to 1.38 it will find them all, 1.38 would only work if compatibility mode with XP SP3 was enabled. The plugin in question is the Amplitube 2... does anyone know why i'm having this problem???
jademan
Forum Crew
Re: Audacity 1.39 problems with VST plugins, 1.38 is fine..
Post by jademan » Mon Oct 05, 2009 12:36 am
takm,
This is a discussion foum; the people perusing here may not be ready to deal with this issue. Since no one has replied yet, would you consider re-posting under the appropriate beta forum ?
Post by steve » Mon Oct 05, 2009 5:57 pm
Audacity 1.3.8 uses the "VST bridge" plug-in (as it had no VST support on its own).
Audacity 1.3.9 now has built in VST support and should be used without the VST bridge.
There's an awful lot of VST plug-ins to test, so developing VST support is likely to be ongoing for quite a while.
Post by Gale Andrews » Thu Oct 08, 2009 1:18 am
stevethefiddle wrote:Audacity 1.3.8 uses the "VST bridge" plug-in (as it had no VST support on its own).
Actually, 1.3.8 was the first version to offer the new VST GUI support without need of the "VST Bridge" Enabler. The difference is probably that while 1.3.8 loaded every plug-in it could find each time it launched, 1.3.9 scans for plug-ins only the first time it finds any, keeping a record of those it does find. On each launch thereafter, it only loads the plug-ins it found and recorded that first time. We made this change so that every launch of Audacity would not be slowed up by a complete rescan.
So to have Audacity detect newly added VST effects, you have to go to the Effects tab of Preferences, check "Rescan VST effects next time Audacity is started", click OK, and restart Audacity. See this "Click here before posting" topic for more details.
