No sound!
kazagger
No sound!
Post by kazagger » Thu Sep 17, 2009 6:49 pm
Hi!
I have exactly the same problem as the guy in this topic:
http://forum.audacityteam.org/viewtopic.php?f=11&t=2899
I've tried all the tips and still no sound! :? :(
And I've lost the green VU-meters. I probably shut them down accidentally... :oops:
Anybody got a solution?
Many thanks in advance!
//Fredrik
Re: No sound!
Post by kozikowski » Thu Sep 17, 2009 7:26 pm
The meters are a big deal.
View > ToolBars > Meter Toolbar.
Play a sound clip and make sure the green bouncing lights meters work. You can download this known, good, working, short sound clip.
http://www.kozco.com/tech/piano2.wav
That should look more or less like this...
http://kozco.com/tech/audacity/Audacity1_playback.jpg
You got all that so far? It doesn't matter if you can't hear it yet.
kazagger
Re: No sound!
Post by kazagger » Fri Sep 18, 2009 6:24 am
Hi!
Thanks for a quick answer. The problem is, after days of agony, resolved... :oops:
I could hear all other sounds, I have no other output choices in Audacity but! I have two speaker jacks in my soundcard. As a longshot (because all else worked) I switched the jacks and there you are: SOUND! Don't ask me why this can be, I don't understand, but it works! As well as the headphone jack.
Sorry for taking up your time, hope this helps others.
***** (replace the stars with any convenient curse of your liking...) SB live crap!
Thanks anyways!
//Fredrik
kazagger
Re: No sound!
Post by kazagger » Fri Sep 18, 2009 4:26 pm
But the meters are still gone...
