Export Multiple
roy windmill
Export Multiple
Post by roy windmill » Thu Sep 17, 2009 9:22 am
Hi, After labelling, and choosing File-Export Multiple, I completed the dialogue box, and then Edit Metadata appeared. I don't understand what all the boxes are for. How to fill them in. Is this dialogue box for the one L.P? or do I fill one in for each"song"? What are "Genres" and "Template" I am using Windows XP with Audacity 1.39. Many Thanks, Roy Windmill
Re: Export Multiple
Post by kozikowski » Thu Sep 17, 2009 7:33 pm
You can safely "OK" that whole window without putting anything in any of the boxes. There is a setting in...
Preferences > Import/Export > Show Metadata Editor.
...which you can turn off and not get that window at all.
