And of course, if anyone is using the "stable" version, let me know if that works better for this function at this point. I have WindowsXP . . . everything flows in terms of it seems to be working when I hit all the buttons, bells and whistles . . . I just either get no reduction in the vocals, or I lose the instrumental with the vocals . . . nothing in between
Trying to Remove Vocals . . . Tried Tutorials . . .
Hey, Everybody . . . new to Audacity; it was suggested by a friend. Got a project that I'm working on for another friend and need to be able to create some "karaoke" tracks. I've followed the tutorial . . . many times . . . but with no luck. If I can get the vocals to even fade, the instrumental is also faded. Anybody got any ideas???
Thanx!
Re: Trying to Remove Vocals . . . Tried Tutorials . . .
Vocal removal doesn't actually work -- or almost never.
There is a very long list of things you can do to screw it up. One of the things is to start with a two track mono show, which is what it sounds like you have. The show must be in stereo -- real stereo -- the singer must not have special effects, the singer must not have stereo echo, the singer needs to be in the middle, most MP3 files fail, etc. etc.
There is a very long list of those.
So you're normal. If you're desperate...
Voice Removal or Isolation
--Center Pan Remover (Voice Remover--Search the page for "Center Pan Remover")
http://audacityteam.org/download/nyquistplugins
--Voice Trap
http://www.cloneensemble.com/vt_main.htm
--Extra Boy
http://www.kvraudio.com/get/1651.html
--Kn0ck0ut
http://www.freewebs.com/st3pan0va/
Enjoy,
--Voice Trap
--Extra Boy
--Kn0ck0ut
Enjoy,
It really depends on the song, you need the vocals to be CENTER PANNED. I use "vocal remove" on my rockboxed ipod and 1/3 of my songs have the vocals completely muted, reverb is the only problem on many...
More from the list:
Any instruments in the dead center -- usually drums and bass-- vanish along with the voice.
Normally you end up with a mono show, not stereo.
Mono masters in any form fail; two track mono or actual single track mono.
Chorus singers are a crap shoot. If they're in the middle, they go, too. If they're off center of stereo spread out, they get left behind.
[sigh] . . . and now Audacity is only appearing in a language other than English . . . I'll give the links you gave me a try, Koz . . . and these songs are older/remastered versions so it may be the recordings themselves and I may have to figure out something totally different
. . . I'll le'cha know if I have any more questions
Thanx Mucho! S
sorry, when i said it worked, I meant as a quick, junky "karaoke effect" not for a studio recording sound...in that case it'll never get close
<<<and now Audacity is only appearing in a language other than English >>>
Edit (third selection) > Preferences > Interface (fourth selection) English (on the right). These settings are different on my machine, so I'm guessing a little.
If that appeared to change by itself, you may have some serious machine stability issues. Have you ever done a Disk Properties Error Test? How much room do you have on your drives?
<<<older/remastered versions so it may be the recordings themselves and I may have to figure out something totally different>>>
If they're old enough, they were never in stereo at all. Stereo is a big deal to getting all these tools to work. The tools make good use of the spacial separation between left and right music. If they were mono performances -- no left and right -- then the chance of getting this to work really is zero.
