Getting at the Help manuals
Re: Getting at the Help manuals
Post by steve » Sun Sep 13, 2009 5:03 pm
Gale Andrews wrote:Looks like the main problem is the Linux eye skimming to the bold text.
I think so too, and IMHO the new text looks a lot more clear.
John Hill wrote:But it would be nice to find out why the local manual doesn't work as it should and get it fixed!
A recent message that I read on the audacity developers mailing list suggests that the problem on Macs has now been identified and fixed, so hopefully it will be OK in the next release. http://n2.nabble.com/help-folder-in-Mac ... l#a3633545
Post by Gale Andrews » Sun Sep 13, 2009 7:53 pm
If you are up to installing our 1-3-10 Alpha you can check out the fix about seven hours from now. Go to:
http://www.audacity.homerow.net/index.php?dir=mac%2F
and get the build from the bottom of the list. The one you want will be dated "2009.09.14-03.15" or later.
Thanks for reporting the problem.
John Hill
Post by John Hill » Mon Sep 14, 2009 8:37 am
This has fixed the problem - all now works as it should! Thank you very much.
John.
