Side Chain Compression?
bat
Post by bat » Sat Sep 05, 2009 8:13 pm
wondering if there's any way to set this up in audacity?
http://sonictransfer.com/side-chain-com ... rial.shtml
I guess the main problem is that Audacity (to my knowledge) can't handle multiple inputs or side chaining...any workarounds or other freebies that could do the trick? I guess i could manually duck each peak in the track :) I think i will if i can't find another way...
bat
Re: Side Chain Compression?
Post by bat » Sat Sep 05, 2009 11:26 pm
Whoa! By only using "fade in", "repeat" and the demo files in the tutorial, I've got the Daft Punk sound kickin'! yess! I love Audacity!
(if anybody knows about multiple inputs though... :)
Post by kozikowski » Sun Sep 06, 2009 2:09 am
Only one multi-track success so far.
http://forum.audacityteam.org/viewtopic ... ack#p47611
bat
Post by bat » Wed Sep 09, 2009 6:52 am
Thanks Kos, but I guess I was more wondering if i could trick a vst into thinking that a stereo track was really 2 different mono ones being fed into the vst? That way i could (for instance) put a mono kick loop in the left channel, a mono synth-horn in the right...you get the idea, and then use "twisted lemon's sidekick" vst to make the horn auto-duck when the kick plays...it's a lot of creative nonsense I was just dreaming up I guess... on second thought though, I'm excited to see if the free Darkwave Studio can do the trick... (crossing my fingers!)
Post by kozikowski » Wed Sep 09, 2009 3:29 pm
Using the tools to the left of the track (black arrow) Split Stereo Track.
You can rejoin them into left and right stereo later.
Post by steve » Wed Sep 09, 2009 5:07 pm
bat wrote:wondering if there's any way to set this up in audacity?
Have you tried the AutoDuck effect in Audacity?
You would need to set all of the time values very short.
You use two tracks - select the upper track and apply the effect. The processed upper track will duck when the level on the track below goes above the threshold level.
Try it with a pad sound on track 1 and a kick drum on track 2.
bat
Post by bat » Wed Sep 09, 2009 9:31 pm
@ fiddler:
you know...i haven't tried the autoduck! lol Defidently worth a TRY, huh? ;)
@Koz:
but will the plugin handle it as 2 channels? That's where I get confused...
thanks for the help!
Post by steve » Wed Sep 09, 2009 9:46 pm
bat wrote:you know...i haven't tried the autoduck! lol Defidently worth a TRY, huh? ;)
You can find instructions for it here: http://manual.audacityteam.org/index.ph ... =Auto_Duck
You will need to set all of the time values very short to get the effect that you are after.
bat
Post by bat » Wed Sep 09, 2009 10:41 pm
kinda funny...i got it to work on one beat...the last one...but it just quiets all the rest (in the middle) wonder why? Is it a setting, or is that just how auto duck works? Gonna mess around with the threshold for a second...
Post by steve » Wed Sep 09, 2009 11:57 pm
bat wrote:but it just quiets all the rest (in the middle) wonder why?
One of the time settings is probably too long. Try starting with all the time settings at zero, then work from there.
Typically you would just use ducking against a strong beat that is not too fast, for example a kick drum or a thumping bass beat. You wouldn't tend to use it against a full drum mix as that would just make the ducking jump around all over the place and sound messy (not what you're after).
It's easiest to hear what's happening if you have the duck amount quite high to start with (say -12 to -18 dB).
I would start with the attack and release times (in the case of Audacity's Auto Duck these are made up of 5 time settings) very fast (try zero as suggested).
Then adjust the threshold so that it ducks on the peaks of the beat. If the threshold is too high (above the level of the beat) then nothing will happen. If it is too low, then the ducking will be triggered by background noise and ringing / sustain rather than the beat itself and it will duck continuously.
Once you have the threshold set right, you can gradually relax the time values to get a smoother response.
With the Audacity Auto Duck, increasing the outer fade time a little will give a bit more space for the beat to come through. Increasing the inner fade time a little will make the effect more subtle by creating an overlap between the beat and the sound that is ducking. Too long on any setting will loose the effect altogether by either ducking everything or ducking nothing.
The Maximum pause (hold) needs to stay very short - say around 0.01 to 0.05 seconds (10 to 50 milliseconds). If this is too long it won't work. If it is too short and you are using a bass track as the trigger then you can get the ducking being triggered by the wave peaks rather than the beat. (Actually, I don't think the Audacity will go that fast, so you are probably protected from that problem even with the Maximum Pause set to zero, but it can be an issue with other software or hardware devices).
When you have your time and threshold set, you can then adjust the "Amount" according to taste (you may also want to tweak the attack and decay times a just little as you adjust the amount).
With a real side-chain compressor you can get a bit fancier by Eq'ing both the trigger and processed signal paths, then mixing the processed signal back in with the original. If you want to get really fancy you can also do this with Audacity by making duplicates of your tracks, then muting the Eq'd trigger track after the effect has been used and adjusting the volume sliders of the processed track and it's original version, but this gets quite complicated and not easy to do without real-time processing.
