You're right. This sure is complicated.
My quibble was with the word "default" in reference to internal processing, and that's what caused my initial confusion. It's true that the default recording quality on a newly initialised Audacity is 32-bit, but regardless of this setting it appears that Audacity still does all internal processing at 32-bit. So I like the new version in the manual.Gale Andrews wrote:The original said 32-bit was used internally by default then 16-bit was used for export by default. That's correct. Default quality on a newly initialised Audacity is 32-bit, and default export is 16-bit PCM WAV (or AIFF on Mac, I think). Other inferences could be made than those made here about what happens if you import a 24-bit file at 24-bit quality.
Well, I tried this. I set the Quality Preferences to 16-bit PCM, created the three tracks (so they were "created" in 16-bit quality), changed the sample format of track 2 to 24-bit and track 3 to 32-bit and generated 10 seconds of silence in each track. Then applied my "do-nothing" Nyquist prompt to the tracks. The same thing happened - tracks 1 and 2 had dither noise, track 3 did not. So the dither appears to be happening when the audio is downsampled from 32-bit after processing and before being returned to the track.Gale Andrews wrote:One minor quibble with what Steve said:
1) Create 3 tracks (it does not matter what the default quality settings are)
2) From the track drop down menu (click on the track name), set the first track to 16 bit, the second to 24 bit, and the third to 32 bit.
3) Select all 3 tracks and generate 30 seconds of silence..., [fade in and the 16- and 24- bit tracks will have dither noise]...
That's not true for the case where you had created tracks in 16-bit quality. In that case after both changing the track sample formats and fading in, the tracks are still silent because they can only be upsampled from 16-bit, so no dither is applied.
I like what's in the manual now. I don't think it's too complicated, and I think it's clearer. I'm not sure what to do regarding the statement about what happens during import, since that is so complicated. If people want to know what happens when they import audio, wouldn't they go to the manual page for File > Import > Audio? But you don't want to overload that section with all these details. A quandry.Gale Andrews wrote:All in all, I'm inclined to revert the Manual back to almost what it was, apart from suggesting people read the Quality Preferences page for more detail. I think that's the place to (try and) explain all this.
-- Bill
