I am trying to add a nyquist plug in called Notch Filter. However once I download it to my Mac (OS 10.5.6) and unzip it I attempt to drag it into the plug-ins folder where it gives me a note of "The item notch could not be moved because plug-ins cannot be modified"
I attempted the usual "Get Info" to overide permissions...however Im not able to change the permissions it's all grayed out. The lock is gray and everything.
Any idea how to get this plug in in there?
Thanks Brad
Adding Notch Filter Plug In
bradbraland
Re: Adding Notch Filter Plug In
Are you on a company or corporation computer?
If not, then you may need to Repair Permissions.
Go > Utilities > Disk Utilities. Select your hard drive and do Disk Verify and Repair permissions.
Systems Operators hate it when you double post. Should I delete the other one?
