Audacity is the only software I'm using right now as a means of creating music (since I was unaware of other higher level software and don't have the money to afford these types of software).
Now I have produced an interesting song in Audacity by making recordings from videos (episodes of anime and Youtube videos) and put those recordings together in making a cool space-like song. However, the song is very inaccurate in that it does not sound very clear at all (it sort of sounds muffled) and I do not have any studio monitoring to accurately adjust the volumes of all the tracks so that it sounds the same on other computers.
Therefore, I need someone (who has good studio monitor headphones or speakers) to adjust the volumes of the tracks and fix the muffleness in the song. I worked hard in producing this song and I think it is very interesting.
I exported all 5 tracks that consist of the song at 44,100 Hz WAV format (Microsoft 16 bit PCM). Therefore, once everything has been successfully done, send the 5 tracks individually back to me (in the same format).
Here is the first track of my song (which is NASA type voices):
http://www.mediafire.com/file/yyxqymnkjqe/NASA Song (Track 1).wav
Here's the 2nd track (which is heavy metal):
http://www.mediafire.com/file/gy3w32x2zzk/NASA Song (Track 2).wav
Here's the 3rd track (which is yelling to give the music "funk"):
http://www.mediafire.com/file/cyfct0w2y0y/NASA Song (Track 3).wav
Here's the 4th track (which is a space-like opera singing):
http://www.mediafire.com/file/z4wmyrmzwfm/NASA Song (Track 4).wav
And here's the 5th track (which are futuristic intercom voices):
http://www.mediafire.com/file/jez5mnkinon/NASA Song (Track 5).wav
A song I made in Audacity (needs work)
Astro-Xana
Re: A song I made in Audacity (needs work)
We'll see what we can do, but next time you post for universal access, try to conform to safe filename guidelines: numbers, upper and lower case letters, dash and underscore only. Some systems don't much like spaces, either.
NASA_Song_Track-01.wav
That's why you sometimes see files written like that. That's the stable way to do it.
You can do whatever you want on your home machine, but the instant you involve Planet Earth, it's best to stick to basics.
