Hello to all,
I can't find the info on wether version 1.3.8 I'm using is a Universal Binary application (if it runs native on either a PowerPC or Intel based Mac) or not; the question is: will it work with snow leopard, even via Rosetta?
I have a project coming up and I'd rather wait to upgrade from leopard until I'm done or even leave it at that because of compatibility problems with other hardware/software at this time...
Thanks
Richard
Audacity and snow leopard
Re: Audacity and snow leopard
Don't upgrade anything just ahead of a job.
We got a note from the System Administrators at work that there are significant problems between Snow Leopard and our corporate network infrastructure.
Thanks Kos, that's what I figured. I'll just carry on for now.
Richard
Richard
