Hi. First time on this forum so apologies if this is the wrong place (but I am running unstable Audacity on Windows).
I want to use the volume envelope from one track to another (I think). What I actually need to do is be able to hear one track when someone is speaking but not hear it if they are silent. Is there a tool to do this? I don't think mixing with a vocoder would work, but I could be wrong.
Thanks.
Apply volumne envelope from one track to another
Re: Apply volumne envelope from one track to another
ramekin,
No. I don't believe so. There is a feature called Time Tracks. It would be interesting to have a concept of a control track, where a control could be used to adjust timing, volume, or possibly even other attributes (eg. pitch, etc.)
I imagine you could go directly into the .aup file and edit the envelope control points. I've never done this myself and I don't know that it would work, but it just might. But don't tell anyone I told you to try this - I might get in trouble.
I think this would make a good New Feature suggestion.
Hi,
Thanks for the reply. I managed to get what I wanted in the end by writing a nyquist script (after intensive Googling) and doing the following:
(mult
(snd-avg (aref s 0) 4100 4100 OP-PEAK)
(aref s 1)
Where s 0 is the voice track and s1 is the breathing track (I think it's that way around, I did it a week or so ago now).
Thanks again for replying.
Mat
(mult
(aref s 1)
Mat
Could you clarify this. What have you got on which tracks and what do you want to do to which track(s)?ramekin wrote:I want to use the volume envelope from one track to another (I think). What I actually need to do is be able to hear one track when someone is speaking but not hear it if they are silent.
:Edit:
OK - see you've sent a reply while I've been typing.
(also found your post on Nabble http://n2.nabble.com/Edit-post-Delete-p ... l#a3596009 )
Yes, sorry - I got impatient!stevethefiddle wrote:ramekin wrote: (also found your post on Nabble http://n2.nabble.com/Edit-post-Delete-p ... l#a3596009 )
