Installing Lamelib
This section is now closed
117165
Installing Lamelib
Post by 117165 » Tue Aug 25, 2009 5:59 am
I have read the guides but I'm still stuck. I download and unpacked Lame Library v3.98.2 and got the file libmp3lame.dylib and tried to going into audacity and locating it for the mp3 exporter but it gives me a notice that it was expecting a library and this file was not reading as one. Is the file supposed to be a document? Or am I doing something wrong?
Re: Installing Lamelib
Post by kozikowski » Tue Aug 25, 2009 4:06 pm
Probably using Audcity 1.2. Do you have a Mac/Intel/Leopard?
Post by 117165 » Tue Aug 25, 2009 6:59 pm
Mac Intel with audacity version 1.2.6
Post by kozikowski » Tue Aug 25, 2009 8:32 pm
We don't often get a clean sweep any more. Audacity 1.2.6 will not run right on an Intel Mac and Audacity 1.2.5 will not run right under Leopard OS-X 10.5.
So rip out Audacity and don't forget the Mystery Preference File...
Trash Mac Audacity Preferences
http://audacityteam.org/forum/viewtopic ... =10#p34670
And then install Audacity 1.3.7.
Audacity 1.3.7 -- Mac
http://audacity.googlecode.com/files/au ... -1.3.7.zip
If you're really the adventurous sort, you can try the regular download Audacity 1.3.8 or the Nightly Build of 1.3.8.
Audacity 1.3.8 Nightly Build -- Mac
http://www.audacity.homerow.net/index.php?dir=mac%2F
