noise removal crashes audacity
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
gregg_hughes
Post by gregg_hughes » Sun Aug 23, 2009 10:34 pm
Good afternoon!
I'm trying to define a noise level for the nose removal. I select a couple seconds of noise (background A/C) and click on Get Profile and the whole app disappears. When I restart audacity offers to recover the project for me.
Has this been fixed in the 1.3.8 build, or should I go back to the stable 1.2.x?
Thanks!
Gregg
jademan
Forum Crew
Re: noise removal crashes audacity
Post by jademan » Fri Oct 02, 2009 2:02 am
gregg_hughes wrote:Has this been fixed in the 1.3.8 build, or should I go back to the stable 1.2.x?
gregg_hughes,
There was work done for 1.3.8, but I'd skip right to 1.3.9. Also, check out this thread: Getting noise removal profile crashes Audacity Beta.
I hope this helps.
Post by steve » Fri Oct 02, 2009 2:09 am
I'd skip to 1.3.10 (cvs) if you can.
