How to repeat something
shroud
Post by shroud » Wed Aug 19, 2009 2:30 pm
How do you make a part of recording repeat itself? I was going to make a nature recording to use as background in my reading audiobook, and wanted to only record about 10 minutes and then make it repeat.
waxcylinder
Re: How to repeat something
Post by waxcylinder » Wed Aug 19, 2009 4:34 pm
1. Select the Audio
2. Copy the selection with Edit > Copy
3. Move cursor to end of track
4. Paste the selection with Edit > Paste
Repeat 3&4 until finished length achieved
Storer
Post by Storer » Sun Aug 23, 2009 10:09 pm
An alternative way is to select all of the track you want repeated, then use Menu->Effect->Repeat, and tell it how many repeats to make. These are treated as individual clips. They will play together seamlessly. If you want to remove the "joints", use CTRL-J (Join). This will also work with an interior selection. The multiple copies will be inserted at the end of the selection, rather than the end of the track, and there will be no "joints" to remove.
Win XP Pro/SP3 ---- Audacity 1.3.12RC2
