There must be something wrong with your methodology.kaynemcgladrey wrote:Based on this I can't help but wonder what the rest of the internet is doing for their screencasting, because I couldn't recommend using a Mac for recording audio based on these tests.
1) Lots of people are using Macs with no such problems.
2) How did you transfer the MP3 files from the Sony to the Mac? Via USB? If so, then the USB port on the Mac must be "acceptably noisy".
3) I did a number of tests using my G5 dual 2GHz (an antique machine, these days).
Audacity set to 32-bit quality, Mac line in volume set to maximum
a) Line in port on Mac open circuit (nothing plugged in), record 10 seconds: b) LIne in port on Mac short circuit (dual-RCA > mini-plug cable plugged in, RCAs shorted), record 10 seconds: Saved project and quit Audacity. Plugged AT2020USB mic into front panel USB port. Selected AT2020B in System Preferences > Sound > Input. Re-opened project.
Set Audacity > Preferences > Devices > Input > Devices to AT2020USB.
Put mic in a camera bag
c) Record 10 seconds from AT2020USB: The line-in port is noisy when open-circuit, as expected. When shorted it is dead quiet. With the mic, the pre-amp noise and room noise dominate the internal noise from the USB port. There's also some hum (60 Hz and harmonics) with the mic, which is probably a limitation of the mic, or EMI floating around my computer room (lights are on a dimmer).
Based on these observations, I would dispute your claim that Macs are not suitable for recording audio.
-- Bill
