Auto "Fit Project"
Auto "Fit Project"
When I zoom in and highlight a part of audio and replace it with silence or tone or whatever, after the edit it will zoom out as if I pressed "Fit Project" button. Which sucks when I need to zoom back in again. I'm guessing this is a bug. Thanks!
Re: Auto "Fit Project"
It's been fixed in newer Audacity code. They're still messing with it.
Until they get it straightened out, here's a shortcut.
When it goes out, it's doing Control-F -- zoom Full.
After it goes out, Control-E to zoom into the silence, then Control-3 to zoom back out slightly. The keys are right next to each other and that puts you very nearly where you were.
Ok, thanks.
